Mini tut :)
8388.14 In reply to 8388.13
Classic ;)
Little correction of the selection of faces of a complete volume!
When you select directly the All volume the SsPlit don't work!
so like on the above image
I said Separate All then SSplit : that work!
But you can also make that! :)
Select one face then select All and then Ssplit that work also!
(because Moi memorize the nature of the selection made by the first selection: point, edge, face,...
Maybe more speedy in calculate than "Separate"! :)
(negative extrude dig up! :)
Export as OBJ Format (Ngones) No problem to import them inside the free TwinMotion !
EDITED: 22 Feb 2020 by PILOU
