There seem to be two versions of the RingCircle2 script, which caused me some confusion.
I made two rudimentary changes, shown in (deleted).
1. Changed the Frame so that the circle is visible in the Top View.
(The profiles then show up in the Front View.)
2. Added input field for Width, (without any code to use it.)
3. Moved US to the first choice.
I was thinking that each profile would have two points, ("Line") associated with it, on the inner side, so that Sweep would be
on the Exterior of the inner diameter. "Orient Line Line" could place the profile on the circle, using the Width to
locate the 2 placement points ("Line") which would accomplish Scaling as well as exterior placement.
This is a busy time of year, so I have not done much :-)
