Hi Pilou, yes that's normal for how it works currently. It's reusing the same code for doing PDF export and so for a perspective view it generates output in PDF "points" coordinates targeting a bounding box of 576 x 768 units ( basically 8 x 10 inches ).
For a non-perspective view like the Top/Front/Right view or the 3D view if it's set to parallel projection the 2D result will be the same size as the objects. Perspective works differently though.
