Hi Michael.
I would also like to add one more thing - When using n-gon export with high threshold angle settings, there is a situation where vertices of the n-gon sitck out and cause a folding of the polygon face. Right now the only solution is to use a lower angle threshold (which drives up the poly count). Is there any way to pull those wayward vertices back in towards the connected faces without lowering the angle threshold (and thereby increasing the poly count)?
jonah
