I've watched Chipp Walters Clips, especially 3DCoat Hard Surface Modeling Tips Vol 1
https://youtu.be/gp1TPRdeYnk
What I really need is HOW TO FIGURE OUT the appropriate settings for EXPORTING a model from Moi3d, and then the APPROPRIATE settings for IMPORTING the model for the purpose of SURFACE MODELLING.
The problem is that most clips give the appropriate settings for THEIR PARTICULAR MODEL - rather than HOW to determine the appropriate settings.
I am hoping there is a PLUGIN or APP that helps walk a model into 3dCoat - that clears out the mess & confusion I'm experiencing attempting manageable byte-sized OBJ transfers between Moi3d & 3dCoat - in this case - for surface modelling - the clay tools - specifically. I design cellphone cases as well as the factory mould, therefore the byte size can be as high as 2 million... however, I can often keep the file size below 1 million.
I'm hanging out over by the pop machine if anyone has any suggestions...
Cheers,
Ignacio VoxHide
