Script for generating Wires
8311.7 In reply to 8311.5
Hi Mindest!
Thanks for the appreciation!
Here are the scripts you asked for.
1) These are the two original scripts written by Michael.
Download the zip file from http://take.ms/6EIBk
Unzip and copy the two .js files into the Moi's "scripts" folder.
2) And this is the modified version that I wrote some times ago.
Download the zip file from http://take.ms/4Pgky
Unzip and copy the four files into the Moi's "commands" folder.
These are the main difference between the original Michael's scripts and my :
1) Michael's file are two .js placed into the "scripts" folder and they are not executed into the Command Processor environment.
This mean that they aren't treated as an "atomic" undoable operation.
And, more important, these scripts move ALL the selected objects, under or on ground, considering the global BoundingBox that contains all that objects.
2) My version is composed by four files placed into the "commands" folder and in this way they can be executed into the Command Processor environment.
This mean that they are treated as an "atomic" undoable operation.
And these commands process all the selected objects but move EVERY single object INDIVIDUALLY, under or on ground.
All these things are clear if you watch this short video : http://take.ms/mjPfT
See you!
