Xtreme Network Curve & Flow on Surface
8288.6 In reply to 8288.3
For making something with one end open and the other closed, using a 'loose' loft, you'd put a point at the end in the same plane as the last profile like this:
Then run Construct > Loft and use the option for "Loft style = Loose":
If you bunch up some profiles near the end it will tighten up the curvature there:
