Transparent shaded view
8253.4 In reply to 8253.1
Hi Karl,
> Ex: If I have two objects inside eachother, it would be nice to be able to
> see the inner object through the outer.
If you turn on the hidden line display (on the side pane enable the View > "Display hidden lines" checkbox), you should then see edges of the inner object in this situation. Either that or hiding the faces of the outer object and leaving its edges displayed can help, like with the script Pilou shows above.
There isn't currently any way to make the shaded surface display of an object to be transparent - unfortunately that's not something that is handled automatically by the video card, it requires polygons to be drawn in a particular sorted order and it has to be implemented carefully to avoid slow downs on more complex models. That's why it's not implemented in MoI as of yet, but hopefully I'll be able to do it sometime in the future.
