File Open Load Placement
8252.2 In reply to 8252.1
Hi Ced, it will open it up however the file was saved - if the object in the file was saved a long ways away from the grid then that's just how the geometry is defined and so it will load it that way...
If you want the object to be closer to the origin, just move it there before you save the file and that's where it will be again when you open it.
You can also set up a shortcut key to move the selected object to the origin, see here: http://moi3d.com/forum/index.php?webtag=MOI&msg=2409.2
