Hi Stardust, a few additional details would probably help, like how would the file name for each separate file be determined, do you want a file save dialog to pop up for each separate file or do you want to see the dialog to choose one base name and then have the other files be numbered versions like name01.fbx name02.fbx .
How do you want to control the meshing parameters for the multi file export, should the meshing dialog show up for each separate file?
> I usually export each named/colored object part in separate file for better control in the render engine.
I guess you'd need to pick one method for the script to do, should it make a separate file for each named object or should it be a separate file for each style?
