Hi Anton, so if I understand right you want the line to establish a common page width?
Is the script you are using the "ExportNamedObjectsToIndividualFiles.js" from above in this thread ( http://moi3d.com/forum/index.php?webtag=MOI&msg=8226.8) ?
Do you want something like the line has a certain name and the script will export that additionally to each file?
So in the script ExportNamedObjectsToIndividualFiles.js, on line 36 it has this currently:
for ( var name in named_objs )
// Clear the selection and then set all objects of this name to be selected.
moi.geometryDatabase.deselectAll();
named_objs[name].setProperty( 'selected', true );
So if you want the line to export with each file, it could go like this:
// new code here:
var line_name = 'reg_line';
if ( name == line_name )
continue; // Don't export the line all by itself.
// select the line so it will export.
if ( named_objs[line_name] )
named_objs[line_name].setProperty( 'selected', true );
I haven't tested that, let me know if it doesn't work.
