Gosper curve
The Gosper curve is a recursive, space filling, fractal curve.
https://spacefillingcurves.wordpress.com/
https://kilin.clas.kitasato-u.ac.jp/museum/gosperex/343-024.pdf
Orders 0 through 3 were generated manually with MoI, fairly easily using rotations and scales and copies and more rotations.
A script is being attempted, which would allow for rounded edges.
EDIT: The command Orient, Line/Line performs the copy align and scale function desired!
It is necessary to deal with directed line segments, "arrows," not just a polyline. I was thinking of using something like:
genseg0.head, genseg0.tail? Or something like part of a half edge data structure?
Red is the "Initiator" arrow line segment, which is order 0.
Blue is the Generator curve, of order 1, with 7 arrow line segments.
Radiant Orchid is the order 2 curve, with arrow heads deleted, and has 7*7 = 49 segments.
Emerald is the order 3 curve, with arrow heads deleted, and has 7*7*7 = 343 segments.
White is the triangle lattice.
There are also other Generalized Gosper curves.
I'd like to router the pattern on a slab of wood...
EDITED: 13 Nov 2016 by BEMFARMER
