Sharing of "experimental and exotics" Nurbs models
8138.5 In reply to 8138.4
Michael thanks for your reply.
You're right, maybe in my previous post I didn't make myself clear...
Let me explain.
> Hi Marco, well I guess it depends on what you plan on doing with the second model....
I know that with the cleanup model I loose the chance to do some things, like untrimming or repairing,
but my intention is to use the cleanup model only when I have totally completed the modelling process, and I want to use the model
for its final purpose, that is, assembly, exporting, rendering...
Instead, I will use the original model if I have to continue to operate on it.
Well...given what I told you, my questions is :
Is it a convenient techinique to run the "ShrinkTrimmedSrf" and "merge" commands in order to get a cleanup model ?
(I refer in particular to the "merge" command)
Thanks for all,
