slow
8133.2 In reply to 8133.1
Hi torsten, well it depends on what particular operation is slow, if it's rotating around the display that has a lot to do with your GPU and not too much on the CPU although that can depend also on whether there are a lot of curves being drawn or not.
Do you maybe have different display settings on your old installation? What are your old values under Options > View > "Meshing parameters" for "Mesh angle" and "Add detail to inflections"?
Or if it's not the interactive view rotation can you describe in more detail about what in particular seems slow? Are you testing it with a heavy enough model to be able to really tell any improvement?
What are the video card specs on your new machine?
