PBR pipeline for MOI3D using 3D COAT and KEYSHOT
8108.76 In reply to 8108.74
Hi Mauro,
> This way it doesn't force the whole browser (and other messages) to go wide. Once someone
> 'clicks' on the image it will open in a new tab at full resolution. Thanks!
> Yes!This is a feature should be implemented by default Michael... ;)
I've managed to modify the forum so that wide images will automatically be shrunken down, when it happens a text label "Image has been resized, click for full size." will appear below the image and if you click on the image the full sized image should open up in a new tab.
If you want the old behavior of no size limiting, you can disable it under forum Options > "Display" section > disable "Resize images and reflow page to prevent horizontal scrolling." checkbox.
