calculations
8099.2 In reply to 8099.1
Hi eric,
> Is there a subroutine that will calculate the area enclosed by a flat closed curve?
Not anything built in, but you might try Max's volume script, I think it also does surface area. You may need to use Construct > Planar to build a surface out of your flat closed curve before using the script. You can find the script here: http://moi.maxsm.net/media/files/ get the one that starts with CVolume.
> and Michael ...can we look forward to dimensions and simple text in the near future?
Sorry no, not likely in the near future, I'm still in the process of working on the port to a 64-bit and Mac native version first. Probably at least a couple more months yet before that step is complete.
