Hi Mike, also another way you can make unit scale transfer from MoI into Modo is to use LWO format and set the option in MoI under Options > Import/Export > LWO options > "Scale output units to meters".
With that option enabled MoI will rescale the LWO output into meter units and that will then synchronize with how Modo's units work.
