Tiny fillets on inset detail
8049.6
Michael, thanks so much! Two things I learned here: the fillet command has a better success rate with on a portion of the surface if it's separated from the rest of a detailed solid/surface. It never occurred to me to cut out that portion of the surface and try running the fillet on those areas. I also had no idea that you could untrim a surface like that. That will come in very handy!
Using your approach, I'm getting much nicer results now. The only question I have is this: is the network tool in this case attempting to create a tangent blend with the surrounding surface? My guess is it's not. Even still, the results are looking really nice. Thanks again!
