Carvewright Flower Frame
8046.5 In reply to 8046.4
After the sweep is done, he hides all the curves he used to create it to get them out of the way.
Then he seperates his swept surface which is a solid so he can do the next command on just a single surface (actually doesn't need that part as the flow command will allow separate surface selection)
then he flows the flowers to the inner surface of his original sweep.
