| Hi Brandroid, I've atttached a version with the middle curve cleaned up so you should get a Network result with it.
 But it's not going to be a great result because there's too much variation between the curves, things like very tight bends are not good to do in a single network.
 I probably wouldn't try to use Network at all to do something like this, I'll see if I can put together some other steps.
