Make2D 4 views script
8041.7 In reply to 8041.6
Hi Anis, when you run the command there is an option for whether to generate invisible lines or not. To enable it, turn on this checkbox here:
When enabled the hidden lines will be assigned to a style named "Hidden lines". If you export to Illustrator you can look for that layer to set up dashed line styles.
