close caps?
8019.3 In reply to 8019.1
Hi glmr,
As a first simple and straightforward test you could use the "blend" command.
Select the first two edges on the same side of both sufaces and run the "blend" command.
Then, select the two surface edges on the opposite sides.
Ciao.
Marco (mkdm).
Size: 174.5 KB, Downloaded: 71 times, Dimensions: 1576x968px
