smooth joint tube airfoil connection
7921.1
I need some sort of a smooth joint between a wing tip and a tube for a computer simulation.
Requirements:
1. The front part of the wing tip should be round and smooth
2. The connection between the tube and the wing tip should also be smooth
3. Both should be smoothly connected to enable a nice flow through the tube and around the model
The red parts in the file are just to give you an idea.
Any ideas how to blend the two parts (black) nicely together?
S.
