how to create a staggered array?
7913.2 In reply to 7913.1
Hi Geof,
The regular Array Grid command works fine.
Start with two circles next to each other diagonally.
Run Array Grid, select both circles, Done, then select spacing points, (red points), on the same diagonal, below left, and above right,
at an appropriate spacing. Note that the green dot, (unused), indicates the relative positions of the red points.
EDITED: 8 Apr 2016 by BEMFARMER
Size: 39.8 KB, Downloaded: 35 times, Dimensions: 293x299px
