Rebuild curves : a possible way to get a seamless curve in order to create seamless surfaces
7912.10 In reply to 7912.8
> Sorry, how exactly works the last script of Max ?
> Must I save first a file ? Make a shortcut? ...
I simply copied the Max's code in a .js file, and saved it the "scripts" directory.
Also the "commands" folder is ok.
To use it, simply select the curves you want to elaborate and run the command.
That's all!
Ciao,
Marco.
