Looking for a compromise for a good workflow involving both Moi V3 and Rhino V5
7909.2 In reply to 7909.1
Hi Marco,
> I'm sorry...i did what you said but every time i load in Moi any file first created in Rhino 5.0
> 3dm format, and save back from Moi, then reloaded in Rhino and saved it again, Rhino
> always shows me the popup that tells me that the file is a 4.0 3dm format,
> and asks me if i want to maintain that format or save it with the new 5.0 format.
Yup, you're right - sorry I got confused about this, I was looking at my most current 3DM code which behaves like I was describing but that's something I had changed just after the MoI 3.0 release. So the next version of MoI is set to behave like I was describing (MoI v4 will write a Rhino v5 3DM if it opened a v5 3DM) but MoI v3 does only write out Rhino v4 3DM files.
> But unfortunately, as you told me, as long as i do any modification to the styles list in Moi
> and overwrite the .3dm file, all the materials infos are lost inside Rhino.
> Pity.....
Well, this is something that you can control - if you need to edit the style/layer list and need to preserve layer material transfer to and from Rhino, do not edit the styles in MoI, edit in Rhino and then you should be ok.
Another way that could work for you would be to set up materials for rendering more at the end of your process after you've completed the models rather than doing it early on.
