Multiple symmetry update
7888.1
I need to create a couple of objects each made up from 6 or more identical symmetry objects
- think of a caleidoscope.
To see the changes made in one curve updating in real time in all objects I used several symmetry
commands instead of the array command as objects created by the symmetry commad will update automatically
if I make a change in the master object / curve.
But what if I want add a new curve to the master object ? I need to create 6 symmetry objects again and
again for the several dozens of curves needed to build up the final shape.
So here my question : Is there a way of automating this process by just one command / is there something
like a radial symmetry / caleidoscope script somewhere ?!
Size: 213.2 KB, Downloaded: 173 times, Dimensions: 1446x1144px
