Wrong G2Blend result on Twisted Surfaces
Hi Michael and all,
I played a bit with the twist deformation tool and control point editing both in Rhino and in Moi.
After some tests i tried to do a G2 blend, first in Rhino then in Moi also, but with wrong results.
The attached .3dm is the file that i exported from Rhino to Moi, and the images illustrate
the steps i followed to select the edges for the blend.
After the G2, or tangency also, blend operation, all i got is a joined surface and not a closed solid.
What am I doing wrong ?
Nice day and thank's,
Marco.
-----POST ADDED------
After checking what i wrote, i realized that i made a mistake.
The tangency surface blend works correctly.
But the G2 blend doesn't work.
Why ?
I can not understand what's wrong in the object's topology.
Marco.
EDITED: 2 Mar 2016 by MKDM
Size: 269.8 KB, Downloaded: 47 times, Dimensions: 1435x1003px
Size: 218.2 KB, Downloaded: 39 times, Dimensions: 1497x967px
Size: 156.7 KB, Downloaded: 50 times, Dimensions: 1619x1001px
