decreasing Network controlpoints?
7846.3 In reply to 7846.1
Hi Lordfox - are you showing the control points of a surface built using Construct > Network there, or is it an offset surface which was offset from a Network surface?
For the network surface itself there are options in the Network command to build a lighter surface, at the cost of the surface not going through the curves with as much accuracy.
For an offset surface that's pretty normal that it will have a lot of points like that. If you want to do control point editing you'll need to rebuild the surface. There is a "rebuild" command in MoI but it currently only works on curves, not surfaces, so you'll need to do a type of manual rebuild which can be done by using the Construct > Curve > Iso command to generate a bunch of isoparm curves on the surface (an Isoparm is a curve that travels along either the U or V directions of a surface), one set in U and one set in V and then use those to do a new Construct > Network and modify the options as needed to make it lighter.
Hope that helps, if you're still stuck please post a 3DM file with the surface in it so I can take a look.
