X,Y,Z coordinates of a Distorted Circle
7792.2 In reply to 7792.1
Hi ed, you can do that by first generating the point objects by creating one point on the curve using Draw curve > More > Point, and then replicating that point along the curve using Transform > Array Curve. Use the "Item count" option in Array Curve to control how many points to generate, they will each be spaced at the same distance as traveled along the curve.
Then once you have the points generated you can select them and use the SavePointFile plug-in script to write their x,y,z coordinates out to a text file. You can find SavePointFile here: http://kyticka.webzdarma.cz/3d/moi/#SavePointFile
