Question about writing a new node.
The scripts in MoI often have Functions{} in their code.
The node programs do not seem to use such Functions{} very much.
Instead they use ...prototype...function().
So to use a function from a script, in a node, should they be written as ...prototype...function()?
Or,
I see that in the Lib folder under nodeeditor\nodes\extensions, there is a file called basicFunctions.js,
which is full of miscellaneous functions.
So when writing a node which uses a MoI script with functions, can or should I put the needed functions in a new lib file called, for example, basicFunctions2.js?
It seems that the functions in basicFunctions.js can be (re-)used in any new node?
