Array Direction with Scale Curve
7763.3 In reply to 7763.2
That's not quite it.
What I'm describing is a repeating pattern where the bounding box of each object is scaled at an increasing rate, with an option to keep the objects connected, creating a taper.
Its similar to the Scaling Rail for the Sweep Tool, except using it for the Array Tool with a Direction.
Think the Eiffel tower, its basically a tapered copy of an object along a curve.
