BOM script
7759.2 In reply to 7759.1
Hi Mik, re: BOM script - the closest thing to that is probably the attached script which I recently wrote for someone else, it allows you to select solids and then it will generate a .csv file similar to what you describe, the file can then be imported into a spreadsheet program.
EDIT: 4/30/2017 - Updated CutList.js to work with locales that use commas as decimal separator
EDITED: 8 Feb by MICHAEL GIBSON
