Hi Bill,
> The problem that I have is that if you draw a line from the leading edge of the engine inlet in the
> top view, it does not line up with the engine in the side view. This misalignment would be critical.
Probably the images are not accurate - if the images are just kind of quick sketches that have differences between them then there won't be any way to align them 100%.
They need to be accurate views of the same exact object if you want them to align properly.
