Gaps between loft and curves
7715.1
Hi all,
I have some gaps between my lofted surface(is that what you would call it?) and the curve I used for lofting. When I added a few more points on the curve, it seemed to make the loft surface more in line with the curve. Is this the best way to make the loft conform to the curves? Or are my curves not realistic? Also, when I make the bottom loft for this hull, how best can I get them to line up nicely?
Dave S.
p.s. for some reason, I couldn't post the image inline to the message. However, it is attached as is the model. Thanks
Size: 31.5 KB, Downloaded: 74 times, Dimensions: 587x563px
