| My only experience with MACROS is in Microsoft Excel, where a series of key presses may be recorded, to reduced repetitive tasks."pressing the Macro key causes the sequence of key presses to be repeated."
 My attempt of a definition of a MACRO in nodeEdit program:
 NOTE: These statements are apparently FAULTY...
 A MACRO is a group of nodes which have been pre-wired, or pre-assembled, to perform some function, or portion, of a full .nod program.
 A MACRO is a building block.  Several MACRO building blocks may be combined to make a .nod program. (?)
 Rather that build a .nod file from scratch, by selecting individual nodes, and wiring them up, the .nod file may be built in smaller blocks. (?)
 A library of pre-defined MACROS may be built up which accomplish common or typical portions of .nod files.
 The programmer loads the appropriate MACROS from the MACRO subdirectory, loads any desired single nodes, (?)
 and wires up appropriate connections between the MACROS and single nodes.(?)
 Example of a super simple MACRO:  A Frequency node wired to a Quartz node.  One selection versus two selections and one wire and one label change.
 I saved Frequency + Quartz as "Clock.nod" to the Macro directory.  (Well, it should be exported...)
 I guess a MACRO is saved by saving a .nod file to the Macro directory?
 I have not managed to load more than one MACRO at a time.
 There is a little box which says Macro, and another little box which says Clock...
 Clicking on the Macro box loads Max's Macro.
 Clicking on the Clock box loads Frequency+Quartz, but Max's Macro disappears...
