Parametric design in MoI?
7713.537
Hi Karsten
thanks for your reply, I have many other questions to ask ,
but let's degrees.....
1-Blend
attached a file that contains two surfaces, you get with your Node Swep,
how do I use the Blend Node?
Swept gives me a single input, the surface, how do I
to extract the edge you want to use for the blend?
2-Blend
I also used two simple curves, I thought
that blend so it worked, I was wrong ....
Can you please show me the use of this Feature ...
Needless to say ... thank you very much
have a nice day,friend
best
al
Size: 299.4 KB, Downloaded: 154 times, Dimensions: 1920x1080px
