Karsten
Thank you very much. I'll check all your code today.
>>In a short test I can't run the circle-node?
My fault. Fixed.
curves.js, line 59
code: var output = factory( 'circle', true, center.getFrame(0), null, this.properties.radius );
>>The original crosshair has in my opinion not enough contrast.
It's looks good for me, but I'll add this line to css
bemfarmer
>>Except for "Clean" :-)
Could you explain, what's wrong with it? My english is far from good. Should I use "Clear" instead?
