Hello Max,
that's really good news - especially the flexible Math-Node - it will reduce the wiring a lot. For me it was clear that most of the nodes has to be rewritten or will some day obsolete. I saw and I see it, as an exercise in JavaScript and the moi-api and I have a lot of fun with it. My intention is to clarify what can to be done with such a system, check limitations and what is most needed. So see me as one of elephants alpha-test-users:-).
In the last hours I fail about the problem to make the link of "Selected" persitent/permanent. The idea was to evaluate the name of the selected object, if it has no name, give it one (simple UUID-routine - example from stackoverflow.com) put it in the label. After store and reload evaluate from label (it seems the informations are in the node file.) But I fail - My limitations:-( - any ideas?
Nevertheless I will show another approach for using such a node-editor:-)
It can also be expanded for clash detection:-)
Thank You very much Max, Pilou, James, Michael, .....
Kind regards
Karsten
