CAD capabilities.
771.6 In reply to 771.5
< also, if i draw a cube in moi, can i export all 6 sides as individual 2d objects from MOI?
Seems yes but you must move each facetts in a same view because you must choose a view before the export!
You can use the function Offset for extract some facetts and after you can move, rotate, as you want etc...your 6 faces in a same view before the export al :)
If you make the export in the 3D view you will obtain some losanges!!!
So use the top, right, front views for have any deformations!!!
