CAD capabilities.
771.4 In reply to 771.1
Hi Hightower, which CAM software are you using?
MoI does currently export to several of the most frequently used CAM formats - STL for triangle mesh data, and IGES for NURBS curves and surface data.
The most recent beta also supports exporting 2D curves to the AI format - you mention WMF and SVG which are somewhat similar to AI format since they are 2D. But AI support tends to be more widespread. Does your CAM program support WMF and SVG but not AI ?
There is definitely an intent to support exporting of geometry to other applications. In future versions I expect to add capabilities to export to more formats (DWG/DXF will be a big one). Version 1.0 is focused more on a core selection of the most frequently used ones.
