Export bug?
7696.3 In reply to 7696.1
Hi Chipp - it seems to export fine over here... From your screenshot it looks like your problem might be that you have not selected the object before doing the export.
Basically in MoI, a File > Export is short for "Export Selected Objects" - it's a way to write just some objects to the file you pick rather than all objects as will happen with File > Save As.
You should normally select the objects you want to export before you run File > Export, or if you just want to save everything instead of a subset, do a File > Save As instead. But if you do a File > Export and you have nothing selected, MoI will pause and a prompt will be shown in the upper right command options area that says "Select objects to export", and MoI will wait there until you select some objects and then push Done (or right-click in a viewport or push enter which are shortcuts for "Done").
The prompt in this situation can tend to be easily overlooked so I have thought about changing this to pop up an error message instead if you don't have any selection since this has caused some confusion. I have tried to avoid these kinds of "in your face" popups but this is a case where it would probably be good to have one.
