OS X El Capitan with MOI
7650.11 In reply to 7650.10
Hi phlatt5th, thanks for trying that. Can you double check the settings in Wineskin (in the Wineskin "Advanced" dialog under Options tab) - the second to last checkbox for "Force use of wrappers quartz-wm ..." should be checked, while the very last one for "Force use of system installed XQuartz ..." should be unchecked.
Is that what you've got?
