Wrapping a texture mesh around a cylinder?
7647.4
Thanks guys.
Getting a bit closer. I re-did the mesh for a much closer end result to what I was thinking. I did manage to get the flow command to work with some extra experimentation and wrapping around half a circle+mirroring the result.
Still some strange issue with edges overlapping, but hopefully I will figure out what is causing the surface alignment issue.
Size: 195.6 KB, Downloaded: 146 times, Dimensions: 718x687px
