Caution in upgrading to El Capitan
7643.6 In reply to 7643.5
Hi Alex,
> Followed the instructions link as detailed but can't see the wineskin.app
> anywhere in the package contents?
Can you please post a screenshot of what you are seeing when you right-click and choose "Show package contents" ?
There should be 4 things, the last one of which is Wineskin.app .
Another thing you can try is to hold down the Alt key on the keyboard and keep it held down while you double click the app. Keep Alt held down until the wineskin dialog pops up, that's a shortcut way to run the internal Wineskin.app
It will probably be a while until MoI is compatible with El Capitan directly "out of the box" - unfortunately Apple tends to make big changes between releases, if you need a stable environment for work it's probably not a good idea to upgrade your operating system right away.
