Hi Alex, I'm not seeing where the "variable" part comes into play in your demo file - do you have any example of what kind of result you would be looking for with the variability and how you would control it?
You can currently get the same result as a variable offset on a line by doing Sweep using some perpendicular lines as the profile curves.
On a bendy curve you can use Flow to get a variable offset like this:
