Variable Width Line Offset Command - fatT Lines
7594.1
Hi All,
Once again amazing to see the script commands flowing love the new Voronoi command have been using Rhino and Grasshopper to do the same but this takes the same task to a new level of simplicity. Awesome Work!
To add to this or any grouped line work would be great to have a command in MOI to variably offset the width both sides, and weld all vertices with a choice of corner radius straight or round.
Currently I do lots of panelling based on linework - I use Illustrator by widening the path width then using pathfinder to weld it all together does a great job. But if this function could be replicated inside MOI would take workflow to another level. This in conjunction with the SubD Command can be used easily to create blended lace structures something currently TSplines is good for.
Here is an example.
I have placed sample 3dm File for review under this location.
https://drive.google.com/folderview?id=0BwzK5muLiElSTnVNU21KdmlsQWc&usp=sharing
