Any way to zoom out all 4 views at once?
7591.4 In reply to 7591.3
Hi Chipp, if by "zoom way out" you mean zoom out so you see all objects inside each view, then yes that's the right-click on that "Reset" button that Danny shows above. Or it's also available by left-click on a button in the side pane under View > "Reset all".
The way it works is if you have a selection on the first button press it will zoom to fit just the selection. If you want to zoom to see everything then click it a second time and it will zoom to fit all objects.
If you left-click the "Reset" button on the viewport bottom toolbar, it will only apply to that particular view. If you right-click it, it will happen in all views at once.
If the second click on the Reset button does not do what you need I guess you'll maybe need to explain a bit more on what kind of zoom you're looking for.
Hope this helps!
