Solid breaks apart after union
7582.1
Hello all,
I have an interesting problem, spent hours to fix it, but did not find any solution.
This should be a buffer for railroad model. (to be 3D printed) From left to right:
cage, spring. union of cage and spring, body attached to cylinder and prism. Until now everything is fine, objects are solids.
But if i try to union the body with a prism, which is just longer than the previous one (exact copy and scale), the solid breaks apart: (but the object it still treated as solid!)
In bottom row I tried to union two solids, the result is much more interesting, one of them is OK, however the second one is broken (but still reported as "solid")
But this happens not always, with different prism size Moi sometimes just do nothing at union.
What else can i try to get 4-5 bodies on one prism to keep it as one object at print?
