Fliped normals
7578.3 In reply to 7578.1
>>Although there isn't a way to visualize in Moi which side is the positive normal side
Not directly but....
This trick works only with single surface, not joined, so you need to copy a one single surface from your joined object. (if you have joined object)
Click command >CPlane< and move the crosshairs along the "edge" and see what happens and cancel command..... File attached....
Other command that use normal's is>Shell< but notice, again single surface.
First method is easy....
Thanks for ....
